Old 02-08-2013, 10:05 AM
Ducky Ducky is offline
Simple toggle function
I am using the pit example.
Goal is to attach 4 quads to the pit screen, thus dividing it into quarters. Then create a sequence that on a key down will give the effect of the quads flashing. I also have a sound clip that goes in sequence with the flashing.
I am trying to create a function that allows for this. I have been able to create the 4 quads (scale, position, etc.), make them fade in and out (flash), and insert the sound clip, which is sequenced to the flash the first time I hit key down. If I hit the key down again the flash sequence will start over but the sound clip does not. The sound clip needs to also loop while the quads are flashing. I have attached my lines of code.
Help would be greatly appreciated. Thanks
